This page provides information on activating and using your Corona Free Trial.
Chaos offers a free trial of Corona for Cinema 4D before purchasing. The trial period has no restrictions within the software such as watermarks. This means that what you see in the trial is exactly what you will get if you have a paid subscription.
The Corona Free Trial activation consists of the following steps:
Fancy Bullets
typecircle
  • Register a new account or sign into an existing one at www.chaos.com
  • Download Corona
  • Install Corona
  • Start your trial
The steps below guide you as a first-timer on how to activate the trial license.
Steps
The steps for activating the trial vary depending on the Corona version you are using:
UI Text Box
typetip
Click any image to view it in higher resolution.
Tabs Container
directionhorizontal
Tabs Page
titleCorona 12, Update 2 and later
UI Steps
sizesmall
UI Step
width60%
Create an Account
Register an account to use and activate the trial, or use an existing Chaos account. For new users, please use this link to register an account: https://accounts.chaos.com/register
Once registered, you will receive an email from Chaos to confirm your account. If you do not receive the email, please check your spam folder in case it has been filtered there. If you still cannot find the email from Chaos, please contact the Chaos support team for further assistance using this link: Contact Support
width5%
width35%
UI Step
Download Trial Product
Go to the Chaos download page to download the latest release. This can be found here: https://my.chaos.com/download/build?product=Corona&platform=Cinema+4D
UI Step
Install Trial Product
Run the installer and complete the installation process as explained on the Installation Process page.
UI Step
width100%
Go to the addresshttp://localhost:30304/ and:
Fancy Bullets
typecircle
  • If you see a green dot next to Online licensing and a Corona icon listed under your products - you are good to go!
  • If you see a Sign in button - click on it and proceed with the sign-in process.
UI Step
width60%
Activate License
Open up Cinema 4D and set the renderer to Corona. You are presented with a pop-up window.
Click Get a free trial and follow the prompts.
UI Text Box
colorlight-red
iconno-icon
Note: If you cannot see the Get a free trial button in the pop-up window, close the window and try again by setting Corona as your active renderer or starting a render.
width5%
width35%
UI Step
width60%
Sign in to your account to activate the trial.
width5%
width35%
UI Step
width60%
Complete the short survey to continue and finalize the activation process.
width5%
width35%
UI Step
width60%
Back in Cinema 4D, the Chaos licensing pop-up window disappears.
width5%
width35%
UI Step
width60%
Chaos Corona for Cinema 4D is now active on your system. You can confirm this from the Corona dropdown menu in the About tab.
A successful activation switches the Activate license button to the Release license button.
Alternatively, you can check the status of your license on the Chaos Licensing Interface
width5%
width35%
UI Text Box
typetip
If you need any help activating Corona or any other product, please contact us
Tabs Page
titleCorona 12, Update 1 and previous
UI Steps
sizesmall
UI Step
width60%
Create an Account
width5%
width35%
UI Step
UI Step
UI Step
width60%
Activate License
Open Cinema 4D and set the renderer to Corona. You are presented with a pop-up window with various options.
Click Activate Trial and follow the prompts.
width5%
width35%
UI Step
width60%
width5%
width35%
UI Step
width60%
width5%
width35%
UI Step
width100%
Go to the address http://localhost:30304/ and:
Fancy Bullets
typecircle
UI Step
width60%
Back in Cinema 4D, you may notice that the activation window is still open. Click Retry to close it.
width5%
width35%
UI Step
width60%
A successful activation results in a greyed-out activation button.
Alternatively, you can also check the status of your license on the Chaos Licensing Interface
width5%
width35%
UI Text Box
typetip
