Saves current postprocessing settings into a file.
Loads postprocessing settings from a specified file.
width
5%
width
45%
width
50%
Auto Adjustment
Exposure– Calculates optimal exposure based on rendered values without tone mapping. To see what exposure values is generated, remove exposure operator(s) in tone mapping and bake auto exposure into tone mapping.
White balance– – Calculates optimal white balance based on rendered values without tone mapping. Bake to see the generated value.
Update during animation– – If enabled, auto adjustments are calculated for each frame of sequence rendering. When disabled, auto adjustments are calculated only for the first frame of the sequence and stay unchanged.
UI Expand
title
Click here to see the Auto Adjustment's UI...
Image Removed
width
5%
width
45%
Image Added
width
50%
Tone Mapping
The Tone Mapping rollout lists the currentlyadded Tone Mapping Operators. By default, it includes the following operators:
Fancy Bullets
type
circle
Simple Exposure
White Balance
UI Text Box
type
note
Starting from Corona 12 Update 1, the White Balance operator has been deprecated and is now called "Legacy White Balance." The new White Balance operator uses Bradford's chromatic adaptation formula, which makes it more accurate and in-line with industry standard.
Green-Magenta Tint
Contrast
Saturation
ACES OT
"+" button – Displays the list of all available Tone Mapping Operators and allows to add one.
Reset button – Resets the current Tone Mapping Operators stack to the default configuration.
Presets button – Displays the list of built-in tone mapping presets.
