Release Notes 30.04.2025
New
  • Improved Roughness Value Handling in SketchUp: Improved synchronization between SketchUp and Enscape by introducing a fallback roughness value, ensuring the roughness setting is preserved when a roughness texture is removed.
  • Improved Handling of Archicad Element Properties: To address performance limitations in the Archicad API, we’ve enhanced the element property system to support lazy loading of additional properties when needed, improving stability and preventing future issues related to incomplete data access.
  • Artistic visual mode performance optimization: Removed rendering flush for contours and extended lines, as recent performance improvements eliminate the need for it - even at 4K - reducing potential slowdowns.
  • Trial Survey Prompt After Exit: A survey prompt will now appear after closing Enscape with a trial license, allowing users to provide feedback, delay the reminder, or opt out entirely.
  • Removed Delay on Asset Placement: Eliminated the 0.25-second delay that previously occurred when placing an asset, resulting in a faster and more responsive asset placement experience.
  • Improved Stability Through Better Error Handling: We’ve improved how Enscape handles internal settings issues to prevent crashes during startup.
  • Normal Maps Now Consistently Handled in White Mode: Previously, normal maps were ignored for transparent or glass materials in White Mode, unlike for opaque materials. This update ensures consistent behavior by supporting normal maps only for opaque materials, clarifying rendering expectations in White Mode.
  • New AI Enhancer icon
Bug Fixes
  • Closing the CAD during Multi-Asset Placement leads to Infinite Error Loop when you Choose to Apply and Leave: Error dialog is displayed only onceand then Enscape quits.
  • Enscape can't start with specific window restore data: Enscape now starts properly.
  • Enscape Version Is Shown On Loading Screen With Customized Background Image: Enscape version is no longer visible on Customized Background images
  • Invalid License Overlay Not Refreshing on New License Error: No valid license overlay is displayed.
  • Section plane is not applied after you edit it once: Section planes are now updated correctly.
  • Video textures skewed due to incorrect row alignment: Video textures are now rendered properly.
  • Renderer crashes for  user paths containing multibyte characters: Renderer starts without crashing.
  • Enscape 4.5.0 Is Not Detected By New Version Check: New versions are now correctly detected.
  • Inconsistent or broken geometry no longer causes Enscape to crash
  • [SketchUp] Document Isn't Properly Closed On Shutdown Leading to Log Spam: The exception on shutdown does not appear anymore in the SketchUp plugin logs.
  • [SketchUp] Time of Day Resets When Creating a New View: The time of day remains the same after creating a new view.
  • [SketchUp] Material Editor albedo colours are incorrect after switching document: Material Editor albedo colours now accurately reflect the selected material after switching document.
  • Inconsistent global illumination: Resolved an issue where Global Illumination (GI) results varied between batch renders of the same views within the same session when using Hardware Ray-Tracing (HWRT) and Real-Time Sun and Sky (RTSS) in Vectorworks. GI is now stable and consistent across consecutive batch exports.
  • [Rhino] Cutout texture rotation does not reflect on the renderer when the mapping type is Worldplane/worldbox for Albedo: Cutout texture rotation now reflects on the renderer.
  • [Rhino] When Deleting an Asset Definition It Will Not Be Added Again: Adding Enscape assets to Rhino is now a consistent behaviour, if an asset is added for which a block definition does not exist a new one is created.
  • [Archicad] Parallel Light Export Error in Enscape 4.5: The light works as it did before
  • [Archicad] Fails To Register on Mac Due To Hebrew System Language: Archicad now registers correctly
Archicad
  • Better Element Properties handling
  • Artistic visual mode optimization
  • Bugfixes and stability improvements
Rhino
SketchUp
  • Improved roughness value handling
Vectorworks
