The following pages contain detailed licensing information and copyright information related to Chaos Anima. For technical information guide on how to set up your license, see the Licensing page.
Fancy Bullets
typecircle
EULA and CGCPP
width40%
When you run the Chaos Anima installer, the first screen will ask you prompt you to read and accept the End User License Agreement and the Global Consumer Privacy Policy.
You can't install or use Anima without accepting these agreements, so take the time to carefully read them.
width5%
width55%
