This page provides information on how to silently install Enscape.
A silent installation allows you to complete Enscape installation without user input during the process using a predefined set of options.
UI Text Box
colorlight-yellow
iconwarning
typenote
By using the Chaos installer for automatic installation with the respective options for that (-auto or -quiet=1), or otherwise installing a Chaos product, you accept the Chaos End User License Agreement and the Chaos Global Consumer Privacy Policy.
Windows
In order for a System Administrator to install Enscape on multiple machines, a config.xml file containing all settings must be first prepared, that will later be used when deploying Enscape on users’ machines.
To learn more about deploying your license to multiple machines, go to this page.
To set up a silent installation and generate a config.xml file, follow the instructions below.
Follow the instructions of the installation and set up the installation the way you want to have it on all machines. Alternatively, if you are creating a basic installation, you can add the -auto tag to automate the installation with all the default options. This will create a file named named config.xml in the folder of the installation executable file. Save this config.xml file as you will need it to install Enscape on other machines.
