This page provides information on how to silently install Enscape.
A silent installation allows you to complete Enscape installation without user input during the process using a predefined set of options.
UI Text Box | ||||||
By using the Chaos installer for automatic installation with the respective options for that (-auto or -quiet=1), or otherwise installing a Chaos product, you accept the Chaos End User License Agreement and the Chaos Global Consumer Privacy Policy. |
Windows
In order for a System Administrator to install Enscape on multiple machines, a config.xml file containing all settings must be first prepared, that will later be used when deploying Enscape on users’ machines.
To learn more about deploying your license to multiple machines, go to this page.
To set up a silent installation and generate a config.xml file, follow the instructions below.
Follow the instructions of the installation and set up the installation the way you want to have it on all machines. Alternatively, if you want to create a basic installation configuration, you can add the -auto flag to automate the installation with all the default settings. This will create a file named config.xml in the folder of the installation executable file. Save this config.xml file as you will need it to install Enscape on other machines.
Description of the Variables for the Installer
VARIABLE | VALUE | DESCRIPTION |
LOCALE | de | Deutsch |
en-US | English (United States) | |
es | Español | |
fr | Français | |
it | Italiano | |
nl | Nederlands | |
pl | Polski | |
pt-BR | Português (Brasil) | |
zh-Hans | 中文(简体) | |
ja | 日本語 | |
STDROOT | path | Specifies the installation location for Enscape. The default for All Users installation is C:\Program Files\Enscape on Windows and /Library/Chaos/Enscape on macOS. |
INSTALL_ARCHICAD | 0/1 | Specifies whether Enscape should be installed for Archicad. |
INSTALL_REVIT | 0/1 | Specifies whether Enscape should be installed for Revit. |
INSTALL_RHINO | 0/1 | Specifies whether Enscape should be installed for Rhino. |
INSTALL_SKETCHUP | 0/1 | Specifies whether Enscape should be installed for SketchUp. |
INSTALL_VECTORWORKS | 0/1 | Specifies whether Enscape should be installed for Vectorworks. |
REMOTE_LICENSE | 0/1 | Specifies Local (0) or Remote (1) License Server. If Remote License Server is specified, its address must be in the LicServer section. |
ANONYMIZED_TELEMETRY | 0/1 | Specifies whether Anonymized Telemetry is enabled. |
PERSONALIZED_TELEMETRY | 0/1 | Specifies whether Personalized Telemetry is enabled. If ANONYMIZED_TELEMETRY is 0, this value will be ignored. |
LicServer | 0/1 | Specifies Host-Port entries for the License Server. Enter the address of the Remote License server here if REMOTE_LICENSE is 1. |
UI Text Box | ||
Please, be aware that the LOCALE, ANONYMIZED_TELEMETRY and PERSONALIZED_TELEMETRY values specified during installation are the default values for new Enscape installations. If users change their preferences later through the Enscape UI inside the CAD, the users' preferences will be serialized in their personal settings.json file and they will not be overwritten by a subsequent Enscape installation. Personal user preferences always take precedence over the default values set by the Installer. The settings.json file is located in %USERPROFILE%\Documents\Enscape\Settingson Windows and in ~/Documents/Enscape/Settings on Mac. |
