Enabled – Turns Swarm, V-Ray's web-based distributed rendering system, on or Distributed Rendering on and off.
Mode – Selects between Classic DR and Swarm Mode.
width
5%
width
30%
width
65%
The new V-Ray Swarm is a web-based distributed rendering system. It’s a simple, yet powerful way to split your rendering across multiple computers.
UI Text Box
color
light-yellow
icon
warning
V-Ray Swarm 2 has released a new version:2.0.17. This update makes the setup process easier by removing the need for an Origin node. Download the latestV-Ray Swarm 2version and see theRelease Noteshere.
UI Text Box
color
light-yellow
icon
warning
V-Ray Swarm 2.0.17 is incompatible with the previously released 2.0.15, i.e. all Swarm instances in the cluster should be updated.
V-Ray SWARM ( ) – Opens up the V-Ray Swarm web interface of the current machine. Alternatively, it can be accessed by typing in the IP address of the current machine on the default port 1113. This allows you to see the swarm render node machines available for rendering jobs in your network. You can see which of the render node machines are connecting to the particular machine that is casting out the render to the Swarm by the IP address next to its status. This interface also allows you to configure the render node machines, tag them, or monitor their resource utilization while rendering.
UI Text Box
type
note
Each machine participating in the render job, including the workstation initiating the rendering process, requires a V-Ray Render Node license.
UI Expand
title
V-Ray Swarm 2.0.15
UI Text Box
type
note
It is important to prepare the network of nodes that take part in the render job before beginning the rendering process. To set up your origin node, follow the steps on the How To Set Up Swarm Clusters page.
If there are multiple origins, remove the redundant ones by closing the Origin script command lines on all machines except for one. Then, make sure to restart the Swarm service on the non-Origin machines.
width
5%
width
30%
Don't Use Local Machine
width
65%
When enabled, the local machine is not used for rendering, while the other Swarm nodes are rendering the image.
