AnchorSettingsGI SettingsGI
Global illumination
SettingsGI | |
SettingsGI |
UI Text Box | ||
See this page for details on the different GI engines. |
By default global illumination (GI) is disabled in an empty scene (with the exception of GPU mode where you can't disable GI). You need to set SettingsGI::on to 1 to enable tracing of secondary rays. Any photorealistic render needs GI, so apart from some kind of debuggingof debugging, you will always want to enable GI.
