Release Notes 20.05.2025
New
  • Veras Integration for Rapid Design Variations: Veras is now integrated into Enscape, enabling fast and intuitive design iteration powered by AI. From within Enscape, the current rendered view can be sent to Veras to generate a range of visual variations ideal for early-stage concept exploration and client discussions.
    By sending high-quality visuals and backend data layers such as material IDs, Enscape enables Veras to produce more accurate and context-aware outputs. Tools within Veras like the Geometry Override Slider, offer fine control over how much the AI output respects the underlying CAD geometry. It’s also possible to apply AI changes only to a chosen part of the image, such as swapping a background or modifying interior elements, while keeping the rest untouched.
    Check here for more information.
width20%
width60%
Image Added
width20%
Fixed Bugs
  • Translate/Rotate/Scale Tool - Material Loss After Discarding Changes: Fixed an issue where deleting an asset using the Translate/Rotate/Scale tool and then discarding changes caused the asset to reappear without its original material.
  • Archicad - Parallel Light Export Error in Enscape 4.5: Fixed an issue where parallel lights in Archicad failed to export. Lights now behave as expected, matching the behavior prior to the update.
  • Incorrect Asset Download Error for Light or Sound Generation: Fixed an issue where an asset download error message was incorrectly shown when a light or sound failed to generate. This no longer triggers an export error.
  • Blocky Sky Artifacts Due to Compression: Fixed an issue where sky visuals appeared blocky and low quality due to compression artifacts, especially when looking at clouds in the rendered scene.
  • [Impact] Performance Map Visualization Stuck in White Mode: Fixed an issue where switching off Impact’s cooling visualization failed to restore excluded assets to their original appearance, and switching to 'None' Rendering Style did not reset the view as expected when White Mode was active.
Known Issues
  • Windows 11 - Crash During Batch Rendering on Some AMD Systems: Enscape may crash during batch rendering when ReSTIR is enabled on certain AMD configurations.
  • Revit - Opening Legacy Collaborative Annotations May Cause Instability: Projects containing older embedded collaborative annotations in Revit 2026 may cause Revit to close unexpectedly and Enscape to become unresponsive when switching to Collaboration mode.
