The Gaussian Splat object can be hidden from camera, like any other geometry object in the scene by using the Primary Visibility option.
alignOn
Alignsection
center
width25%
Image_comparison_slider
LabelBefore
width50%
LabelAfterOffAttachmentImageBefore01_Cam-On_ShReflRefr-On.pngAttachmentImageAfter02_Cam-Off_ShReflRefr-On.png
Before after
afterLabeloff
beforeLabelon
Panel
Image Added
Panel
Image Added
width25%
height50%
Anchor
Refl
Refl
Example: Visible in Reflections
The Visible in Reflections option controls if the Gaussian Splat object is reflected in other objects in the scene.
alignOn
Alignsection
center
width25%
LabelBefore
width50%
LabelAfterOffAttachmentImageBefore01_Refl-On_CamShRefr-On.pngAttachmentImageAfter02_Refl-Off_CamShRefr-On.png
Before after
afterLabeloff
beforeLabelon
Panel
Image Added
Panel
Image Added
width25%
height50%
Anchor
Refra
Refra
Example: Visible in Refractions
The Visible in Refractions option makes the Gaussian Splat object seen by other objects in the scene that exhibit refractive properties.
align
Alignsection
center
width25%
LabelBeforeOn
width50%
LabelAfterOffAttachmentImageBefore01_Refr-On_CamShRefl-On.pngAttachmentImageAfter02_Refr-Off_CamShRefl-On.png
Before after
afterLabeloff
beforeLabelon
Panel
Image Added
Panel
Image Added
width25%
height50%
Anchor
castS
castS
Example: Casts Shadows
This example shows how the pink flamingo can produce shadows when the Casts Shadows option is enabled, and doesn't block light when it's not.
align
Alignsection
center
width25%
LabelBeforeOn
width50%
LabelAfterOffAttachmentImageBefore01_Sh-On_CamReflRefr-On.pngAttachmentImageAfter02_Sh-Off_CamReflRefr-On.png
Before after
afterLabeloff
beforeLabelon
Panel
Image Added
Panel
Image Added
width25%
height50%
Anchor
Matte
Matte
Example: Affect Matte Surfaces
When Affect Matte Surfaces option is enabled, the Gaussian Splat is considered as background and receives shadows from the casting object.
align
Alignsection
center
width25%
LabelBeforeOn
width50%
LabelAfterOffAttachmentImageBefore01_Affect_matte_surfaces-Off.pngAttachmentImageAfter02_Affect_matte_surfaces-On.png
Before after
afterLabeloff
beforeLabelon
Panel
Image Added
Panel
Image Added
width25%
height50%
Anchor
Color
Color
Example: Color
