HideElements
cssselector#tocVertical, #tocHorizontal
This page contains links to Chaos Envision release notes organized by build version number.
Build Version Notes
Page Tree
root@self
startDepth3
Envision 0.4.0
Beta Release, Update 4
Date - March 27, 2025
UI Button
colorblue
titleSign up for Chaos Envision Beta
urlhttps://www.chaos.com/envision#join
UI Button
colorblue
newWindowtrue
titleDownload Chaos Envision Beta
urlhttps://download.chaos.com/?platform=47&product=77
Improvements
  • Added ability to automatically detect and render the Environment parameters coming from the .vrscene file.
  • Source path customization for opened/linked referenced scenes.
  • Moved Embed functionality from File->Import menu to linked scene's details setting.
Crash Fixes
  • Random crashes in unit scaler when loading large scene.
Envision 0.3.0
Beta Release, Update 3
Date - February 26, 2025
New Features
  • Add support for Sketchup UVW scale attribute during import.
Improvements
  • Updated the timeline play-head design.
  • Color Corrections: when the type is set to Ampas, non applicable parameters are hidden.
  • Color Corrections: highlight burn is disabled when Filmic tone-map is on as it is not applicable in that case.
  • Disabled Seams blend of textures when Make Seamless is disabled.
Crash Fixes
  • Failure to detect dedicated GPU leads to crash and Lavina renderer issues.
  • GPU device instance suspension, system ran out of resources leads to crash.
  • Crash when trying to render a simple scene.
  • Crash after texture assignment on enhancements and tweaking of properties (regression).
  • Material foliage no longer works (regression).
  • Assert - Stack.h Line: 526, application close during asset download (conditional).
Bug Fixes
  • Mix top-material cosmos discovery blocked by active search filter.
  • Scatter layer model list gets squashed after editing (regression).
  • HDRi assignment discovery blocked by active filters (regression).
  • Camera gizmo is not updating when child constraint is transformed (regression).
  • Details panel buttons get cropped with high DPI scaling (conditional).
  • Crowd generation overrides active actor paths of other crowds (regression).
  • Scatter over line preset cannot be applied on spline target.
  • Light gizmo not updating when child constraint is transformed (regression).
  • Layer material selection remains active during pick top mix operation.
  • Duplicate plugin names in multiple scenes conflict.
  • Favorites category entry not updating properly while selected (conditional).
  • Cosmos search filter discovery resets once category is changed (conditional).
  • Variants marked as favorite are not discoverable in favorites section (conditional).
  • Cosmos buttons (3d, materials, hdri) not linking back to the parent category.
  • Scatter layers cannot be renamed (regression).
  • Onboarding screens overlapping on document load (conditional).
  • Onboarding screen buttons are misaligned/spacing issues.
  • Select Material process cannot be cancelled in Full-Screen mode.
  • Escape to revert for material picker no longer works (regression).
  • UI locked when all three onboarding screens are present (regression).
  • Cosmos Spline presets cannot be dragged on viewport splines.
  • Onboarding warning screen warning points to invalid location (conditional).
  • Font scale/crop issues with resolution indicator in viewport overlay & scene stats (regression).
  • Scatter layers cannot be removed/deleted (regression).
  • Cosmos categories labels should not be cut but positioned on two rows.
  • Preferences window is still labeled as Application Settings.
  • Full-screen button highlights remain active when exiting/entering mode (conditional).
  • Angle to up vector not working for newly added scatter layers (regression).
  • Variant assets missing numbering in their tooltip.
  • Scatter instance generation gets triggered on material hover.
  • User getting crashes in Envision.
  • Material displacement no longer works (regression).
Envision 0.2.2
Beta Release, Update 2
Date - January 24, 2025
Cosmos
  • Added marking assets as favorite in the bottom dock and filter by favorite.
  • Improved categories browsing with buttons and category path.
  • Added support for 4D characters via Cosmos.
  • Added the ability to import scatter presets from Cosmos.
  • Added support for Cosmos assets with variants.
Functional
  • Added full screen mode for presenting.
  • Added “Rounded corners” Material enhancement.
  • Added quality presets for viewport rendering.
  • Improved map button behavior.
  • Added reset buttons restore from linked scene.
  • Added a button for material editing.
Miscellaneous
  • Improved consistency of the reset buttons.
  • Improved UI for the Cosmos tab.
  • Improved UI of scrollbar size and spacing.
  • Added tooltips for Filter by scene and revert transformations.
  • Various UI adjustments
Bug Fixes
  • Crash after texture assignment and then accessing material properties.
  • Crash when accessing material filter by scene with no document loaded in.
  • Crash upon selecting all nodes.
  • Downloaded only checkbox has extended focus/hover trigger.
  • Excessive noise/shimmering or ghosting of characters or vegetation affected by wind.
  • "Downloaded only" cosmos option doesn't update properly after a filter is applied.
  • Slow loading of embedded material thumbnails on scene load.
  • Non-consistent details panel show/hide behavior when spline tool is active or a spline control point is added.
  • 4d Character texture/material flickers during animation playback.
  • Camera pivot/gizmo flickering during animation.
  • UI lock/freeze when simultaneous asset download takes place.
  • Incorrect animated actor orientation/facing when scattered along surfaces.
  • Cosmos HDRI selected from preview not working when mix material is used.
  • Scatter layer properties cannot become unique after the node is duplicated.
  • Invalid actor speed property range.
  • Release build import failure for HDRIs.
  • Render output progress-bar is not indicative of the actual rendering process.
  • Regressions & inconsistencies with material drag & drop onto multi material surfaces.
  • Incorrect displacement unit scaling.
Envision 0.2.1
Beta Release, Update 1
Date - December 18, 2024
Bug Fixes
  • Cannot render still image while animation is running.
  • Fix issue with drag and drop actor in crowd list.
  • Proxy(GeomMeshFile) scale is not imported correctly.
  • Invalid mpeg output with specific aspect ratios.
  • Bind character to spline path leads to wrong transforms.
  • Scatter still visible when hidden.
  • Can not pick dummy as look at target.
  • SVG icons are pixelated on systems with DPI scaling.
Crash Fixes
  • Prevent out of memory issues when exporting video with resolution above 7680(8k).
  • Failure to detect dedicated GPU leads to crash and renderer issues.
Envision 0.2.0
Beta Release
Date - December 3, 2024
Initial Beta
Import & Referencing
  • Link vrscene files created in any supported CAD tool.
  • Update the linked vrscene while preserving modifications.
Scene and environment variations
  • Create multiple variations of your scene and/or environment, and quickly switch between them.
Chaos Scatter
  • Scatter any Cosmos asset on surfaces or along lines.
Crowd simulation
  • Use animated characters from Cosmos to simulate walking crowds or stationary people.
Camera
  • Physical cameras with control over Aspect ratio, Two-point perspective and a flexible management.
  • Animate the camera with keyframes, along a spline and following a specific target.
  • Tweak color corrections per camera.
Build advanced animations
  • Timeline with dedicated tracks for scene variants, environment variants and cameras.
  • Different animation types for blending between variations.
Simple yet powerful material editor for editing and enhancing materials
