Progress Bar Container
step2
Progress Bar - Hyperlink Step
titleStep 1: Install Chaos Envision
url Installation
titleStep 2: Activate your license
urlLicense Activation
titleStep 3: Start Chaos Envision
urlStart Chaos Envision
Activation Steps
UI Steps
sizesmall
UI Step
width60%
If you have a Named license, follow these steps. The steps are the same for connecting to an online floating license pool.
The first time you use
Chaos
Envision, a prompt to log in with your Chaos account may appear.
Sign in
width5%
width35%
Image Added
UI Step
yellow
width60%
Enter your Chaos credentials.
UI Text Box
colorlight-green
icontip
typetip
You can use your Chaos account credentials.
Your existing Envision, Enscape, V-Ray, Corona, Anima or Veras logins are all Chaos accounts and work for all our products.
UI Text Box
colorlight-
cyan
icon
warning
info
typeinfo
If you have never had a Chaos account, you can create one at this step.
width5%
width35%
Image Added
UI Step
width60%
You can close the login page after seeing the confirmation for a successful login.
You can now start using your Chaos product
You cannot proceed using Chaos Envision without signing in
width5%
width35%
Image Removed
Image Added
Floating Licenses
Floating Licenses can be shared between multiple users and can be used completely online or within a local network, depending on the setup.
UI Text Box
colorlight-cyan
iconinfo
If your organization prefers to centrally manage licenses, enable anonymous device-based access, or deploy licenses within an offline or secure network environment, refer to the License Server Deployment page.
Fancy Bullets
typecircle
  • You can use the License Server that is installed automatically with Envision to check the availability of your licenses. Refer to the Viewing Your Available Licenses page for more information.
  • If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the Troubleshooting page for possible solutions.
