Progress Bar Container
step2
Progress Bar - Hyperlink Step
titleStep 1: Install Vantage
url Installation
titleStep 2: Activate your license
urlChaos License Quick Start Guide
titleStep 3: Load Vantage
urlLoad Chaos Vantage
Activate the License
The Chaos License Server is the bridge between the Chaos Product and the Chaos Account associated with a given license. You cannot use any Chaos product without a license.
You connect to the License Server by installing the license application locally on your machine or connecting to a machine in your local network that has a shared floating license set up.
If you are hosting a Chaos License Server for multiple machines, please see the Administrator Workflow.
Please follow the instructions for your subscription plan:
Activation Steps
width60%
If you have a Named license, follow these steps. The steps are the same for connecting to an online floating license pool.
The first time you use Vantage, a prompt to log in with your Chaos account may appear.
width5%
width35%
Image Added
width50%60%
Alternatively,If you are connected to a Cloud-Based Floating License, follow these steps.
Fancy Bullets
typecircle
  • During the default installation, the license application is installed locally on your machine. For more information on the specifics of the installation, go to the Installation page.
  • Open Vantage
  • and
  • a notification prompts you to sign in
  • go to Help menu > Chaos account.
  • Click Sign in and enter your Chaos account credentials on the Chaos accounts Sign in webpage
  • Select Sign in from this dialog.
width5%
width35%
Image Added
width60%
Fancy Bullets
typecircle
  • Enter your Chaos credentials.
UI Text Box
colorlight-green
icontip
typetip
You can use your Chaos account credentials.
Your existing Vantage, Enscape, V-Ray, Corona, Anima or Veras logins are all Chaos accounts and work for all our products.
UI Text Box
colorlight-cyan
iconinfo
typeinfo
If you have never had a Chaos account, you can create one at this step.
width5%
width45%
Image Removed
35%
Image Added
The License
width50%
60%
You can close the login page after seeing the confirmation for a successful login.
You can now start using your Chaos product.
UI Text Box
colorlight-yellow
iconnote
You can use the License Server that is installed automatically with Vantage to check the availability of your licenses. See how here
width5%
width35%
Image Added
Floating Licenses
Floating Licenses can be shared between multiple users and
can be used
When doing a shared setup, the license holder needs to install the license locally on at least one machine in the network. Installing the license happens automatically when you perform a default Chaos product installation. If you only need to install the License Server application separately, see the Installation page. This machine can use the license, but it also serves as a connection point for others to connect to the license. If you are the license holder, i.e., the administrator, see the Administrator Workflow page.
Here is how to connect to an already set-up Premium shared license:
Fancy Bullets
typecircle
  • The administrator needs to give you their machine's IP address. This serves as your connection point to the Chaos License.
  • When installing your Chaos product, at the Licensing step, select Remote. In the Primary License Server field, type the server IP address that your license administrator gave you. At the end, add the :30304 port.
  • Continue to finish the installation. You are connected to the active licenses after that.
completely online or within a local network, depending on the setup.
To use an online floating pool, your Administrator needs to add you to their Organization. This sends an automatic email confirmation, which also contains a link you can use to create an account, if you don't have one yet.
After that, you can follow the same activation steps as above to connect to the online floating pool.
  1. Proceed with a default installation.
  2. Sign in with your Chaos Account when prompted.
If you are an Administrator in an Organization, see the Cloud-Based Floating Licensing pagefor a guide on how to share licenses through the my.chaos portal.
UI Text Box
colorlight-cyan
iconinfo
If your organization prefers to centrally manage licenses, enable anonymous device-based access, or deploy licenses within an offline or secure network environment, refer to the License Server Deployment page.
width5%
width45%
Image Removed
Troubleshooting
If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the the Troubleshooting page for possible solutions.
borderColorred
borderStylesolid
Next Step
Go to step 3 to see how to load Vantage.
