UI Steps
sizesmall
UI Step
width60%
Visit the Free Trial Page
Go to the Corona Trial Page and click Start your trial under the product you would like to try. You can choose whether your license is Named or Floating, whether you want the Solo or Collection product bundle, and if you would like the subscription to be monthly or annual. To learn more, see: Chaos Suite offerings.
width5%
width35%
UI Step
width60%
Complete the Checkout Process
Enter your email address and billing details, and complete the checkout process.
UI Text Box
colorlight-cyan
iconinfo
Billing starts automatically after the free trial. Cancel before it ends to avoid getting billed.
width5%
width35%
UI Step
Activate your Chaos Account (non-registered users)
UI Text Box
colorlight-cyan
iconinfo
If you already have a Chaos account, you can skip this step.
After completing the checkout process, you will receive an account setup email from Chaos. Use the link in the email to set a password and activate your account.
UI Step
Download and Install Corona
width30%
1. Click the Download button to be redirected to the Active Products page in my.chaos.com.
width5%
width30%
2. Here, again, click the Download button next to the newly acquired Corona subscription.
width5%
width30%
3. On the Download page, choose the Cinema 4D version you are using and the operating system, and click Download for Windows or Download for macOS. When the download is complete, run the installer and follow the on-screen instructions to complete the installation.
UI Text Box
colorlight-cyan
iconinfo
To learn more about the installer and its options, see Installation Process.
UI Step
width60%
Log in To Use the Product
When you open up Cinema 4D and set the renderer to Corona, a pop-up window appears. Click Sign in. Once you are signed in, the you can use Corona with your trial license is activated, and the pop-up window in Cinema 4D disappears.
width5%
width35%
UI Step
width60%
You can now use Chaos Corona for Cinema 4D is now active on your system. You  You can confirm this from the the Corona > About window.
A successful activation switches the Activate license button to the Release license button.
Alternatively, you can also check the status of your license in the Chaos License Server
width5%
width35%
