Comment: general policy to NOT show the popup window as it suggests people might decline it in the installator
If different users install and then use Anima, the Service agreement window appears upon the first launch of Anima.
Image Removed
width40%
When you run the Chaos Anima installer, the first screen will prompt you to read and accept the End User License Agreement and the Global Consumer Privacy Policy.
You can't install or use Anima without accepting these agreements, so take the time to carefully read them.
width5%
width55%
width25%
width50%
width25%
