Progress Bar Container | ||||||||||||||||||
Activate the License
Chaos Licensing is the bridge between the Chaos Product (Anima) and the Chaos Account associated with a given license. You cannot use any Chaos product without a license.
You connect to the License Server by installing the license application locally on your machine (default installation process), or by a using a (remote connection to) floating license from a shared pool of licenses.
Local Chaos License Server on This Machine
Activation Steps
UI Steps | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Remote Chaos License Server on the Network
If you have multiple Anima licenses, they can be shared between multiple users and devices in one of two ways.
- The easiest way to do so is to use My Chaos Portal options and enable Floating licensing sharing. See how in the Cloud-Based Floating Licensing article or video included.
OR
2. Alternatively, you can set up a local network by installing the license server on one machine and sharing its IP address to the rest of the users in the network. For further details on how to do it, see the License Server Deployment article.
Change Chaos Anima License Settings
Section | ||||||||||||||||||||||
Floating Licenses
Floating Licenses can be shared between multiple users and can be used completely online or within a local network, depending on the setup.
To use an online floating pool, your Administrator needs to add you to their Organization. This sends an automatic email confirmation, which also contains a link you can use to create an account, if you don't have one yet.
After that, you can follow the same activation steps as above to connect to the online floating pool.
- Proceed with a default installation.
- Sign in with your Chaos Account when prompted.
If you are an Administrator in an Organization, see the Cloud-Based Floating Licensing pagefor a guide on how to share licenses through the my.chaos portal.
UI Text Box | ||||||
If your organization prefers to centrally manage licenses, enable anonymous device-based access, or deploy licenses within an offline or secure network environment, refer to the License Server Deployment page. | ||||||
Section | ||||||
Column | | |||||
Column | ||||||
Troubleshooting
If you are experiencing any difficulty installing or running the Chaos License Server, please refer to the Troubleshooting page for possible solutions.
UI Text Box | ||||
Chaos Anima licensing requires uninterrupted Internet connection. If the connection stops for more than five minutes, Chaos Licensing will stop working. | ||||
Visit the Chaos Licensing section of the documentation for further details on the Chaos License Server, such as how to check your license expiration and status, how to access various settings, and more advanced options. |
Next Step
Go to step 3 to see how to load Anima.
