The Gaussian Splat object can be hidden from camera, like any other geometry object in the scene by using the Primary Visibility option.
LabelBefore
Alignbefore-after
alignafterLabelcenter
Image_comparison_slider
Off
beforeLabelOn
width
Panel
50%
borderStyle
LabelAfter
none
Off
Image Added
height
Panel
borderStylenone
Image Added
50%
Example: Visible in Reflections
The Visible in Reflections option controls if the Gaussian Splat object is reflected in other objects in the scene.
LabelBefore
Alignbefore-after
Off
beforeLabelOn
width
Panel
50%
borderStyle
LabelAfter
none
Off
Image Added
height
Panel
borderStylenone
Image Added
50%
Example: Visible in Refractions
The Visible in Refractions option makes the Gaussian Splat object seen by other objects in the scene that exhibit refractive properties.
LabelBefore
Alignbefore-after
Off
beforeLabelOn
width
Panel
50%
borderStyle
LabelAfter
none
Off
Image Added
height
Panel
borderStylenone
Image Added
50%
Example: Casts Shadows
This example shows how the pink flamingo can produce shadows when the Casts Shadows option is enabled, and doesn't block light when it's not.
LabelBefore
Alignbefore-after
Off
beforeLabelOn
width
Panel
50%
borderStyle
LabelAfter
none
Off
Image Added
height
Panel
borderStylenone
Image Added
50%
