width65%
It is also possible to export images with an embedded alpha channel. This feature is only available when setting the file format to either .png, .exr, .tga.
To enable an image to be exported with an embedded alpha channel, make sure the checkbox for Apply Alpha Channel is checked.
The Alpha Channel export also includes information for transparent and semi-transparent materials. This means that if the sky is visible behind a semi-transparent surface, that background (sky) will be removed, without losing the reflection of the objects located in front of the surface.
width5%
width25%
Apply Alpha Channel option
width65%
UI Text Box
typenote
If you find you are not getting crisp clean edges on an exported image (where blue / red artifacts on an edge will be visible when zoomed in on the exported image) when Apply Alpha Channel is enabled, then set the Chromatic Aberration slider in the Enscape Visual Settings -> Image -> Effects section to 0. Here’s a comparison between the Chromatic Aberration slider being set to greater than 0 (enabled) and with the slider set to 0 (disabled).
column
width5%columnwidth
Before after
afterLabel
On
beforeLabel
Off
25%alignalign
Panel
borderStyle
none
Image Added
Panel
borderStylenone
Image Added
center
Image_comparison_slider
LabelBeforedisabled
LabelAfterenabled
AttachmentImageAfter
Default Folder
width65%
If you specify a Default Folder location in the Visual Settings’ Output tab, using the Screenshot will open the Save Screenshot dialog at that specified location. It is therefore still possible to change the location on the fly.
When using Batch Rendering, the action is the same, unless you link a named View to a Setting Preset, in which case, the location that each named View is rendered out to is dependent on the location specified in the linked Setting Preset.
This means you can assign each named View an individual and specific location when Batch Rendering.
width5%
width25%
Default Folder option
