Section | |||||||||||||||
Outlines can be used to highlight individual forms, achieving a more illustrative look. The thickness of the outlines can be controlled using the outline slider. Here is a quick comparison of outlines varying from 0 to 75 percent.
Section | |||||||||||||||||||||||||||||||||||||
White Mode Overrides
Polystyrol Mode
You can see the effect of 0% Transmission in the following screenshots with 25% and 75% outlines applied.
Before afteralign | |||||||||||
Image_comparison_slider | | ||||||||||
width | 50% | ||||||||||
AttachmentImageBefore | rs_win9_4-0.png | ||||||||||
AttachmentImageAfter | rs_win10_4-0.png | height | 50%
Bump Maps
Light View Temperature Gauge
width | 45% |
This gauge will only be viewable in the Enscape window, and is not included in rendered images.
Before after | ||||||||||||
| 5%
| column
| width
| 50% | ||||||||
Column | ||||||||||||
You can also combine Light View mode with Outlines. In the example, Outlines are set to different % values.
Before after | ||||||||||||||||||||||
| 5%
| column
| width
Sketch Mode
