Section | |||||||||||||||
Column | |||||||||||||||
If you find that,
when Apply Alpha Channel is enabled, you are not getting crisp clean edges on an exported image (where blue/red artifacts on an edge are visible when zoomed in on the exported image), then set the Chromatic Aberration slider in the Enscape Visual Settings > Image > Effects section to 0. Here’s a comparison between the Chromatic Aberration slider being set to greater than 0 (enabled) and the slider set to 0 (disabled).
Before after | ||||||||||||||||||||
| 5%
| column
| width
Default Folder
