width50%60%
The Sheen Glossiness Render Channel is analogous to the Reflection Glossiness Render Channel; the main difference is that all Sheen render elements can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Advanced > V-Ray Sheen Glossiness
width5%
80%
width45%35%
Image Added
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAftersheen glossiness
height
Properties
width50%
Enable Deep Output  Specifies whether to include this render channel in deep images.
width5%
width45%
