The Sheen Filter Render Channel isanalogous to the Reflection Filter Render Channel; the main difference is that all Sheen render channels can be subtracted from the main back-to-beauty composite, graded, and added back in.
The Sheen Filter Render channel stores reflection information calculated from the materials' reflection values in the scene. Surfaces with no reflection values set in their material(s) contain no information in the render pass and, therefore, render black.
While the Raw Sheen Reflection Render Channelgives the full reflection of objects reflecting in the scene, Sheen Filter RE shows how muchof that reflection should come through in the composite. In other words, the filter defines the strength of the reflection, while the raw image defines what is being reflected in the image. When these two channels are multiplied, the true level of reflection is given and produces theSheen Render Channel. Using these component parts of the reflection, you can fine-tune the reflection in your final composite.
Channel Name– Customizable name for the render channel.
Enable Deep Output–Specifies whether to include this render channel in deep images.
Color Mapping–Applies the color mapping options specified in theColor Mapping rollout of the V-Ray tab in the Render Settings window to this render channel. This option is enabled by default.
Consider For Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Filtering – – Applies an image filter to this channel.Derive Raw Channels – Generates data in the raw channels by combining the respective color and the filter color channels.
Vfb Color Corrections– Applies the post-render color adjustments made from the VFB.
Denoise– Enables the render channel's denoising, provided theDenoiseris enabled.
