The Raw Sheen Render channel is analogous to theRaw Reflection render channel; the main difference is that all Sheen render channels can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Raw > V-Ray Raw Sheen Reflection
width
5%
width
45%
Image_comparison_slider
LabelBefore
beauty render
width
80%
LabelAfter
raw sheen reflection
AttachmentImageBefore
AttachmentImageAfter
height
80%
35%
Image Added
Properties
width
50%
Channel Name– Customizable name for the render channel.
EnableDeep Output–Specifies whether to include this render channel in deep images.
Color Mapping–
Consider For Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections– Applies the post-render color adjustments made from the VFB.
Denoise– Enables the render channel's denoising, provided theDenoiseris enabled.
