width50%60%
Two or more objects in the scene can share the same Object ID.
The The Object ID Render Chanel channel creates selection masks based on Object ID that show each object (by Object ID) in a solid, unshaded color.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Matte > V-Ray Object ID
width5%
80%
width45%35%
Image Added
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAfterstool selected
height
Properties
width50%
Enable Deep Output – Includes this render element in deep images.
width5%
width45%
