Cryptomatte is a method developed byPsyopfor efficiently encoding accurate mattes. It typically uses three to five automatically generated render channels stored in a multichannel OpenEXR file which removes the hassle of creating dozens or hundreds of Multimattes.
Compared to the Multi Matte Render Channel, Cryptomatte offers the following:
It does not require a setup with object IDs, etc.
Only requires a fixed number of additional render channels, typically four.
It cannot be propagated through reflections or refractions.
width
5%
width
45%
Image_comparison_slider
LabelBefore
beauty render
width
80%
LabelAfter
cryptomatte channel
AttachmentImageBefore
AttachmentImageAfter
height
80%Image Added
Properties
width
50%
Channel Name– Customizable name for the render channel.
Enable Deep Output– Specifies whether to include this render channel in deep images.
Id Type– Specifies how the ID mattes are determined.
Node Name– Creates mattes by node names. Node Material Name – Creates mattes based on the materials in the scene. Node Name with Hierarchy– Creates mattes by node names and takes the node hierarchy into account for linked or grouped objects. Node User Attribute– Creates mattes from a property specified in theUser Attribute field. Node Asset/reference name– Creates mattes based on Cinema 4D References made within the scene.Note:This does not create mattes based on Cinema 4D Assets, only file references. Node Layer Name – Creates mattes based on the layer names in the scene. Sub Object Name– Creates separate mattes for each individual object within a V-Ray Proxy when the proxy file contains more than one object. This option works by getting IDs from within the V-Ray Proxy by creating a mask for each sub-object of the proxy (.abc and .vrmesh). This type produces masks for V-Ray Proxy objects only - regular geometry is not included in this cryptomatte layer.
User Attribute– Specifies a user-defined attribute for creating ID mattes when theID type is set to V-Ray user attribute.
Add Root Object Name– When ID Type is set toSub object name, it specifies what information about the sub-object names goes into the Cryptomatte manifest. The dag path and the sub-object name(s) (e.g., MeshName.abc/ObjectName) are added to the manifest.
Number of Layers– Specifies the number of layers for the render channel, which determines the number of objects that can be distinguished per pixel. If multiple objects intersect at a single pixel, higher-order layers will contain non-zero results. The default value of 6 is normally enough for most cases.
Write Metadata– Determines whether or not the render channel saves the metadata.
