width50%60%
The Coat Glossiness Render channel is analogous to the Reflection Glossiness Render Channel, with the main difference being that all Coat render elements can be subtracted from the main back-to-beauty composite, graded, and added back in.
UI Path: ||V-Ray Node Editor|| > World > Render Channels > Advanced > V-Ray Coat Glossiness
width5%
80%
width45%35%
Image Added
Image_comparison_slider
LabelBeforebeauty render
width80%
LabelAftercoat glossiness channel
height
Properties
width50%
Enable Deep Output  Specifies whether to include this render channel in deep images.
width5%
width45%
