If you have a Named license, follow these steps. The steps are the same for connecting to an online floating license pool.
Fancy Bullets
type
circle
Start Chaos Envision fromStart menu > Chaos Envision > Chaos Envisionor search it directly in the Start menu.You can also start it from its installation directory. The default directory is C:\Program Files\Chaos\Envision where you can find and execute the Chaos Envision file.
width
5%
width
35%
Image Removed
UI Step
width
60%
Fancy Bullets
type
circle
The first time you use Envision, a prompt to log in with your Chaos account may appear.
width
5%
width
35%
UI Step
width
60%
Enter your Chaos credentials.
UI Text Box
color
light-green
icon
tip
type
tip
You can use your Chaos account credentials.
Your existing Envision, Enscape, V-Ray, Corona, Anima or Veras logins are all Chaos accounts and work for all our products.
UI Text Box
color
light-cyan
icon
info
type
info
If you have never had a Chaos account, you can create one at this step.
width
5%
width
35%
UI Step
width
60%
You can close the login page after seeing the confirmation for a successful login.
You can now start using your Chaos product.
UI Text Box
color
light-yellow
icon
note
You can use the License Server that is installed automatically with Envision to check the availability of your licenses. See how here.
