changes.mady.by.user Kristin Ivanova
Saved on May 23, 2025
changes.mady.by.user Alexander Yolov
Saved on Jun 03, 2025
You can start Chaos Anima from the Start menu, or from the desktop shortcut created with the installation.
The first time you use Anima, a prompt to log in with your Chaos account may appear.
Enter your Chaos credentials.
You can use your Chaos account credentials.
Your existing Envision, Enscape, V-Ray, Corona, Anima or Veras logins are all Chaos accounts and work for all our products.
If you have never had a Chaos account, you can create one at this step.
You can close the login page after seeing the confirmation for a successful login.
You can now start using your Chaos product.
You can use the License Server that is installed automatically with Anima to check the availability of your licenses. See how here.
