Section | ||||||||||||||||||||||||||||||||
Expand | ||
V-Ray 7, (7.10.0001)Official release Date- May 16 Jun 9, 2025 Improvements and& Bug Fixes Added support for Revit 2026 Chaos Scans (VRscan materials) can now be loaded and rendered correctly without a Scans license. The entire Chaos Scans material library is now available in Cosmos Chaos Account management window is implemented. It can be accessed directly from the toolbar before V-Ray is activated, or from the Help menu after activation A new distributed rendering mode called Classic DR is implemented. Use it as an alternative to Swarm by manually configuring the network environment The handling of all license errors is improved The V-Ray installer now requires a CPU with AVX2 instruction set support to run The V-Ray scene (.vrscene) export no longer requires a license Rendering of specific RPC materials is improved Gaussian splats can now be assigned to Families via drag-and-drop in the Appearance Manager Proxies are renamed to Geometries in V-Ray’s Paths & Sharing Settings. Geometry assets are now correctly stored in XML settings files Rendering certain Cosmos light assets no longer causes a V-Ray Core exception An issue that leads to an error when turning artificial lights off during Interactive Rendering with specific Cosmos assets is resolved An issue causing the View Selector to appear between two monitors when opening Revit on a second monitor is resolved The Cosmos Browser no longer sinks behind Revit when the Asset Editor is focused An issue preventing the VFB from closing in specific situations is resolved An issue causing an error when attempting to render or release the V-Ray license after running Rhino.Inside is resolved
Thumbnailspagesettings | ||||||||||||||||
