width50%
To save a preset:
  • Select the Scatter object you want to use as a preset from the Objects tab. This displays its parameters in the Details tab.
  • In the Details tab, give a name to the Scatter preset and click to save it.
  • The preset is now available in the Local Library tab () in the bottom dock panel.
width5%
width45%
Multimedia
nameSavePreset.mp4
width560
height315
Image Removed
Click on the gif to enlarge it.
width50%
To load a preset:
  • Open the Local Library tab () in the bottom dock panel, and expand it.
  • Select a preset from the Local Library.
  • Drag the preset and drop it into the viewport. Ensure there is a surface available onto which you can drop the preset.
width5%
width45%
Multimedia
Image Removed
nameLoadPreset.mp4
width560
height315
See also:
Thumbnailspagesettings
ThumbnailOverlayRectangleColour0,0,0
ThumbnailOverlayRectangleOpacity0.5
ThumbnailBGImageHeight100px
ThumbnailOverlayOpacity0
ThumbnailSubTextSize13px
ThumbnailTextColourWhite
ThumbnailTitleTextSize22px
ThumbnailOverlayRectangleHeight80%
ThumbnailOverlayRectangleBottomPadding10px
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1000px
Columns1repeat(3, 1fr)
Columns1width1540px
Columns2width1290px
