width50%
To create a camera from current view:
Fancy Bullets
typecircle
  • Click the Create camera from current view () button in the Camera tab on the left.
    Two black bars appear at the top and bottom, marking the limit of your camera's field of view.
  • Move around until the perspective matches what you have in mind.
  • When ready, it is a good idea to lock the camera's position through the button so you don't accidentally change it later on.
width5%
315
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/4btBKqUmbUE" title="Chaos Envision: How to create cameras" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Multimedia
nameCreate_Camera.mp4
width560
height
Edit Cameras
width50%
To edit camera parameters:
Fancy Bullets
typecircle
  • Select the camera in the Camera tab on the left.
  • Go to the right-hand side Details tab.
    There you can adjust the position, rotation, FoV, DoF, Exposure, or add color corrections. You can also rename the camera or lock it for further transformations through the  button.
    All changes are automatically saved.
For more information on the individual camera parameters, refer to the Camera Details page.
UI Text Box
colorlight-green
icontip
Don't forget to unlock the camera before making any transformations to it such as changing its position or rotation.
UI Text Box
colorlight-green
icontip
Right-click on a parameter to revert it to its default value.
width5%
315
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/zEVy-JDORhc" title="Chaos Envision: Editing cameras" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Multimedia
nameEdition_3.mp4
width560
height
width50%
To add Depth of Field (DoF):
Fancy Bullets
typecircle
  • Select the camera in the Camera tab in the left-hand side panel.
  • In the right-hand side Details tab, enable the Depth of field toggle.
  • Pick a focal point or adjust the Focal distance.
  • Adjust the Aperture.
width5%
315
width45%
HTML
<iframe width="560" height="315" src="https://www.youtube.com/embed/ozgMAzuRi_g" title="Chaos Envision: Controlling the Depth of Field" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
Multimedia
nameDoF_2.mp4
width560
height
Animate Cameras
Check our Chaos Academy lessons to learn how to animate cameras: Animate Camera Lesson
