This page contains information about the V-Ray Rock Texture.
Page Contents
stylecircle
width50%
The V-Ray Rock Texture generates a procedural rock pattern using two colors or texture maps.
width5%
width45%
UI
Paths
width33%
||mat Network|| > V-Ray> Texture > V-Ray Rock
width33%
||shop Network|| >
V-Ray Material > V-Ray> Texture > V-Ray Rock
width33%
Node
The TexRock node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
Image Added
Color 1 – Controls the first of the two colors used by the V-ray Rock procedural.
