This page provides information on the Extra Texture render channel.
Page Contents
maxLevel3
stylecircle
Floatingpagetoc
The Extra Texture Render Element shows the rendered image with a single texture applied to all objects in the scene. The texture applied to the scene can be a bitmap or a procedural texture such as VRayDirt or VRayCurvature .
UI Path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > ExtraTex
The parameters for this render channel appear in the Parameters tab under the out Network and within the render channels node.
Filtering – Applies the image filter to this channel. Image filter settings are in the AA sub-tab of the Sampler tab of the V-Ray Renderer node.
