The Color Channel is a container node that allows the output of almost every render channel available in V-Ray. It allows you to extract different color components from the image (i.e. Diffuse, Reflections, Refractions, etc.) to use used later for tasks like compositing.
UI Path
UI Path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > Color Channel
The parameters for this render channel appear in the Parameters tab under the out Network and within the render channels node.
Type – Allows you to select which color information to extract from the image as a separate channel. For more details, please see the Channel Types table below.
Name – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.colorchannel.vrimg).
The table below provides a list of the channels that can be separated out with the Color Channel render pass.
width65%
TypeDescription
AtmosphereAtmospheric effects, such as Environment Fog.
Diffuse
Pure diffuse surface color.
ReflectionReflections on the surface.
RefractionRefractions of a surface.
Self IlluminationSelf-illumination of the surface.
ShadowDiffuse light blocked by other objects.
SpecularSurface specular highlights.
LightingDiffuse direct surface lighting.
GIThe diffuse surface global illumination. Only present if Global illumination is enabled.
CausticsThe caustics on the material. These caustics are present only when the Caustics option of V-Ray is enabled. This channel does not include GI caustics.
Raw GIRaw diffuse global illumination (not multiplied by the diffuse surface color). Only present if Global illumination is enabled.
Raw LightingRaw diffuse direct illumination before it's multiplied by the diffuse surface color.
Raw ShadowRaw light blocked by other objects.
VelocitySurface velocity of an object. This render element is useful for generating motion blur in post-production.
Render IDNode render ID of the object that contributes most to the pixel value.
Material IDMaterial ID of the object.
Node IDReturns solid un-shaded colors to represent a numerical identifier set through that object's Attributes, Object Property, or assigned material. Useful for selection masks. .EXR and .vrimg formats store as integer values.
Z-DepthZ-depth of the surface.
Reflection FilterReflection filter (the color by which the raw reflections are multiplied to give the final surface reflection). This can be considered an alpha channel for reflections.
Raw ReflectionPure surface reflection before it is multiplied by the reflection filter color.
Refraction FilterThe refraction filter mitigates the raw refraction layer. This render element returns the color by which the raw refractions are multiplied to give the final surface refraction. This can be considered an alpha channel for refractions.
Raw RefractionPure surface refraction before it is multiplied by the refraction filter color.
Real Color
Shows the original colors that were clamped or adjusted with Color Mapping.
NormalSurface normals in screen space (which is not the same as camera space). To output the normals in camera/object/world space, use Maya's Sampler Info utility texture node.
BackgroundImage background, such as any Background Texture specified in the Environment render settings.
AlphaAlpha transparency.
Color
Generic render element container used for referencing other render elements of type RenderChannelColor containing color information .
Wire ColorThe wire color of the object as set in the 3ds Max scene. This can be used to generate masks for the objects based on their wire color.
Matte / ShadowMatte shadow part of the image.
Total LightingBoth direct and indirect lighting in the scene.
Raw Total LightingSum of all raw lighting, both direct and indirect.
Bump / NormalNormals generated by bump maps, in screen space (which is not the same as camera space). Use the VRaySamplerInfo utility texture node to get the normals in camera, world or object space.
SamplerateShows an image where the pixel brightness is directly proportional to the number of samples taken at that pixel.
SSSRenders just the subsurface part of the V-Ray SSS material on a separate layer.
DR BucketIdentifies the render node responsible for rendering a bucket during distributed rendering.
Reflection GlossinessReturns a float value that corresponds with the Reflection Glossiness value of an object's material.
Reflection HilightsReturns a float value that corresponds with the Highlight Glossiness value of an object's material.
Refraction GlossinessReturns a float value that corresponds to the Refraction Glossiness value of an object's material.
Shademap Export
Reflection Alpha
Reflection IORStores floating-point information that corresponds to the Fresnel IOR values of scene objects' materials.
Material Render ID
Noise LevelOutputs the noise level for pixels. Same as the noiseLevel render element produced by the VRayDenoiser, but as a standalone render element.
width45%
Image Added
