This page gives an overview of the Specular Render Element and explains how it is used.
Floatingpagetoc |
Section | |||||||||||||||
UI Path
: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > Color Channel > Type > Specular
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Consider for Anti-Aliasing – When enabled, anti-aliasing will be used where possible.
