This page gives some basic details about the Refraction Glossiness render element and how it is used in compositing.
Floatingpagetoc |
Section | |||||||||||||||
UI Path
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > Color Channel > Type > Refraction Glossiness
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Consider for Anti-Aliasing – When enabled, anti-aliasing will be used where possible.
