The Color Channel is a container node that allows the output of almost every render channel available in V-Ray. It allows you to extract different color components from the image (i.e. Diffuse, Reflections, Refractions, etc.) to use used later for tasks like compositing.
UI Path
Section | ||||||||||
The parameters for this render channel appear in the Parameters tab under the out Network and within the render channels node.
Type – Allows you to select which color information to extract from the image as a separate channel. For more details, please see the Channel Types table below.
Name – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.colorchannel.vrimg).
Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings are applied to the current render channel.
Consider for Anti-Aliasing – When enabled, anti-aliasing will be is used where possible.
Filtering – Applies the image filter to this channel. Image filter settings are in the Image Sampler tab of V-Ray Renderer node.Color Mapping – When enabled, the Color Mapping options in the render settings will be applied to the current render
channelDenoise – Enables the render element's denoising, provided the Denoiser render element is present.
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
