width33%
||mat Network|| > V-Ray> Ray > Procedural Texture > V-Ray Soft Box
width33%
||shop out Network|| > V-Ray Material > Render Elements node > V-Ray> Ray > Procedural Texture > V-Ray Soft Box
width33%
Node
The TexSoftbox node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
Image Modified
Use Base Texture – When enabled, the Base Texture will be is used instead of the Base Color.
Base Gamma – A gamma correction that will be is applied to the texture.
Use Base Tint – When enabled, the color in the Base Texture parameter is multiplied by the Base Tint Color parameter.
Tint Strength – A multiplier that controls how strong the effect of the Base Tint Color parameter is.
Radial Vignette
Image Added
Enable – Enables the radial gradient.
Radial Vignette Flip – When enabled, reverses the radial gradient.
Vertical Vignette
Image Added
Enable – Enables the vertical gradient.
V Vignette Flip – When enabled, reverses the vertical gradient.
Horizontal Vignette
Image Added
Enable – Enables the horizontal gradient.
U Vignette Flip – When enabled, reverses the horizontal gradient.
Frame Vignette
Image Added
Enable – Enables the frame gradient.
Frame Vignette Flip – When enabled, reverses the frame gradient.
Use Frame Tint – Enables the frame tint.
Tint Color – Specifies a color to tint the frame.
Tint Strength – A multiplier that controls how strong of an effect the Tint Color has.
Enable Frame Noise – Enables frame noise.
Noise Amount – Specifies the amount of frame noise.
Noise Size – Specifies the scale of the frame noise.
Noise Phase – Specifies the phase of the frame noise.
Fractal Noise – When enabled, generates a fractal noise pattern.
Fractal Levels – When Fractal Noise is enabled, this controls the number of fractal iterations.
Spots
Enable  – Enables or disables the hot/dark spot.
Spots Mode Mode – Specifies how the hot/dark spot is applied.
Hot Spot Spot – Color is added to the texture, adding brightness and creating a hot spot.
Dark Spot Spot
– Color is subtracted from the texture, removing brightness and creating a dark spot.
Softness  – Controls the rate at which the hot spot fades out.
Inner Radius  – Specifies the inner radius where the hot spot begins to fade out as a fraction of the texture size.
Outer Radius  – Specifies the outer radius where the hot spot ends as a fraction of the texture size.
Spots Multiplier  – A multiplier for the brightness of the hot/dark spot.
U/V Offset  – Controls the position of the spots along the U or V axis.
U/V Tiling  – When enabled, controls the tiling of the spots along the U or V axis.
Spots Tint On On – Enables the tint color for the spots.
Spots Tint Color  – When enabled, controls the color of the hot spot.
Spots Tint Strength  – A multiplier that controls how strong the strength of the Tint Color parameter.
Vertical Vignette
Image Removed
Horizontal Vignette
Image Removed
Radial Vignette
Image Removed
Frame Vignette
Image Removed
Color Color Tweaks
Mult – Specifies a strength multiplier for the texture color.
Alpha – Alpha channel is drawn from the texture.
Color Intensity / Luminance Color
– Alpha is generated from pixel intensity.
Opaque
– Alpha channel is fully opaque.
Use – Differentiate between textures exported from different applications. You can choose between Color Intensity (3ds Max) and Color Luminance (Maya).
Mult – Specifies a multiplier for the texture alpha.
Invert – When enabled and Invert from Color Tweaks is also enabled, the resulting texture alpha will be inverted is inverted as well.
Placement
Placement Type – Specifies the way the valid portion of the texture is applied.
U – Specifies the U coordinate of the valid texture sector.
VSppecifies Specifies the V coordinate of the valid texture sector.
