V-Ray for Houdini offers the following several mapping nodes. They are used together with textures inside the V-Ray Material node Mat Network to specify how to interpret UV coordinates on the mesh.
UI Path
 ||shop
width33%
||mat Network|| > V-Ray > Mapping
Image Added
width33%
||out Network|| > V-Ray
Render Elements node > V-Ray > Mapping
width
33%
Mapping Types
Fancy Bullets
typecircle
Additionally, the Environment Settings node (Env Settings) can be created from the Mapping category.
