Section | |||||||||||||||
The parameters for this render element appear in the V-Ray RenderChannelColor render channels node.
Denoise
Deep Output – When enabled, this render element is included in deep images.
Color Mapping – When enabled, the Color Mapping options in the render settings are applied to the current render channel– Enables the render element's denoising, provided the Denoiser render element is present.
Consider for Anti-Aliasing
– When enabled, anti-aliasing
is used where possible.
Filtering
– Applies the image filter to this channel. Image filter settings are in
the Image
of the Sampler tab
of the V-Ray
UI Text Box |
This render element is not supported with V-Ray GPU rendering. |
