This page provides information on the BodyForce Body Force component.
The BodyForce helper object Body Force produces a force toward a geometry object that can be used for giving shape to the fluid. The force is pronounced outside the body, but the inside is replaced with a mechanism that suppresses the fluid's escape.
Strength | strength – Specifies the force intensity. This parameter mostly affects the points outside the body. The fluid accelerates constantly towards the body until reaching it. Note that this parameter can be negative, so fluid gets repelled by the body.
UI Text Box | ||||
You can set the Strength parameter to a negative value so the fluid gets repelled by the body. |
