Enable Resimulate from the Resimulation rollout.roll-out.
In the case of a Liquid simulation, the original cache files will be replaced with the ones generated by the Resimulation process. Newly created Foam, Splash, Mist or Wetmap particles will now be present in the files on disk.
You can always remove them by Resimulating, with the respective Particle Group disabled in the UIThe Resimulation process generates an additional sequence of cache files on your hard drive. You can always disable Resimulate to go back to your source cache, and enable it again to switch to the new content.
width
60%
width
40%
You can now head over to the Foam or Splash/Mist tab and enable either of those.
