The below materials use BRDFVRayMtl as a base to load in Lavina.
BRDFAlSurfaceReflectionReflection Reflection glossinessReflection Reflection :
PluginSupport
BRDFALSurface
  • Diffuse
  • Diffuse strength
  • Reflect
  • Reflect strength
  • Reflect roughness
  • Reflect IOR
  • Reflect distribution
  • GGX
BRDFBump
  • Base BRDF
  • Bump texture color
  • Bump texture float
  • Bump texture multiplier
  • Bump texture
BRDFCarPaint
  • Base color
  • Base reflection
  • Base glossiness
BRDFDiffuse
BRDFDiffuse_forSSS
  • Color
  • Color texture
  • Color texture multiplier
BRDFGlass
BRDFGlassGlossy
  • Color
  • Color texture
  • IOR
  • Affect shadows
  • IOR texture
BRDFLight
  • Color
  • Color multiplier
  • Affect GI
BRDFScatterVolume
  • Overall color
  • Color
BRDFSkinComplex
  • Diffuse color
  • Diffuse amount
  • Shallow color
  • Shallow amount
  • Medium amount
  • Medium color
  • Deep color
  • Deep amount
  • Primary reflection color
  • Primary reflection amount
  • Primary reflection fresnel IOR
BRDFSSS
  • Color
  • Color texture
BRDFSSS2
  • Diffuse reflectance
BRDFSSS2Complex
  • IOR
  • Overall color
  • Diffuse color
  • Subsurface color
  • Specular color
  • Specular amount
  • Specular glossiness
BRDFStochasticFlakes
  • Hilight glossiness
  • Reflect filter
  • BRDF Type: GGX
BRDFToonMtl
Loads as BRDFVRayMtl, toon parameters are ignored.
BSDFPointParticle
Loads as a simple diffuse BRDF.
VRayMtl
Tabs Container
directionhorizontal
Tabs Page
title3ds Max
UINative nameV-Ray plugin Name (plugin/parameter)Support
 VRayMtlBRDFVRayMtl
Diffuse
diffuse
(tick)
Diffuse Texturediffuse
(tick)
Roughnessroughness
(error)
Roughness Textureroughness
(error)
Reflectreflect
(tick)
Reflect Texturereflect
(tick)
Reflect Glossinessreflect_glossiness
(tick)
Reflect Glossiness Texturereflect_glossiness
(tick)
Fresnel reflectionsfresnel
(error)
Fresnel IOR
fresnel_ior
(tick)
Fresnel IOR Lockfresnel_ior_lock
(tick)
Fresnel IOR Texturefresnel_ior
(tick)
Metalnessmetalness
(error)
Metalness Texturemetalness
(error)
Max depthreflect_depth
(error)
Reflect on back sideoption_reflect_on_back
(error)
Dim distance
reflect_dim_distance
(error)
Dim fall offreflect_dim_distance_falloff
(error)
Subdivsreflect_subdivs
(error)
Affect channel
reflect_affect_alpha
(error)
Refractrefract
(tick)
Refract Texturerefract
(tick)
Refract Glossinessrefract_glossiness
(error)
Refract Glossiness Texturerefract_glossiness
(error)
IORrefract_ior
(tick)
IOR Texturerefract_ior
(tick)
Abbe numberdispersion
(error)
Affect channelrefract_affect_alpha
(error)
Max depthrefract_depth
(error)
Affect shadowsrefract_affect_shadows
(tick)
Subdivsrefract_subdivs
(error)
Fog colorfog_color
(error)
Fog color Texturefog_color_tex
(error)
Fog multiplierfog_mult
(error)
Fog biasfog_bias
(error)
Translucencytranslucency
(error)
Scatter coefftranslucency_scatter_coeff
(error)
Fwd/bck coefftranslucency_scatter_dir
(error)
Thicknesstranslucency_thickness
(error)
Back-side colortranslucency_color
(error)
Back-side color Texturetranslucency_color
(error)
Light multipliertranslucency_light_mult
(error)
Self-Illuminationself_illumination
(tick)
Self-IlluminationTextureself_illumination
(tick)
GIself_illumination_gi
(tick)
MultTexCombineColor / result_multiplier
(tick)
Compensate camera exposurecompensate_camera_exposure
(error)
Microfacet GTR (GGX)brdf_type=4
(tick)
Wardbrdf_type=2
(tick)
Blinnbrdf_type=1
(tick)
Phongbrdf_type=0
(tick)
Use glossiness / Use roughnessoption_use_roughness
(tick)
GTR tail falloffgtr_gamma
(error)
GTR tail falloff Texturegtr_gamma
(error)
Anisotropyanisotropy
(error)
Anisotropy Textureanisotropy
(error)
Rotation
anisotropy_rotation
(error)
Rotation Textureanisotropy_rotation
(error)
Local axisanisotropy_axis
(error)
Map channelanisotropy_derivation
(error)
Trace reflectionsreflect_trace
(error)
Trace refractionsrefract_trace
(error)
Cutoffoption_cutoff
(error)
Env. priorityenvironment_priority
(error)
Glossy Fresneloption_glossy_fresnel
(error)
Preserve energyoption_energy_mode
(error)
Double-sidedoption_double_sided
(error)
Use irradiance mapoption_use_irradiance_map
(error)
Fog system units scalingfog_unit_scale_on
(error)
Effect IDMtlMaterialID / material_id_number
(error)
Opacity modeopacity_mode
(error)
Diffuse Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Reflect Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Reflect Glossiness Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Refract Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Refract Glossiness Texture MultiplierTexCombineColor / texture_multiplier
(error)
Opacity Texture MultiplierTexCombineColor / texture_multiplier
(error)
Bump Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Displace Texture MultiplierTexCombineColor / texture_multiplier
(error)
Self -illum Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Diff. rough Texture MultiplierTexCombineColor / texture_multiplier
(error)
Fresnel IOR Texture MultiplierTexCombineColor / texture_multiplier
(tick)
Metalness Texture Multiplier
(error)
Anisotropy Texture MultiplierTexCombineColor / texture_multiplier
(error)
An. rotation Texture MultiplierTexCombineColor / texture_multiplier
(error)
GTR falloff Texture MultiplierTexCombineColor / texture_multiplier
(error)
(tick)
Translucent Texture MultiplierTexCombineColor / texture_multiplier
(error)
Fog color Texture MultiplierTexCombineColor / texture_multiplier
(error)
Environment TextureBRDFVRayMtl / environment_override
(error)
Tabs Page
titleSketchUp/Rhino
Placeholder
Tabs Page
titleModo
 VRayMtlBRDFVRayMtl
Diffuse colordiffuse(tick)
Diffuse roughnessroughness(error)
Roughness Modelroughness_model(error)
Self-Illumination colorself_illumination(tick)
Self-Illumination affects GIself_illumination_gi(tick)
Compensate Camera Exposurecompensate_camera_exposure(error)
BRDF Type (Ward, Blinn, Phong, GGX)brdf_type(tick)
Reflection colorreflect(tick)
Use roughnessoption_use_roughness(tick)
Reflection glossinessreflect_glossiness(tick)
Reflection roughness
Hilight glossinesshilight_glossiness
Lock hilight glossinesshilight_glossiness_lock
GGX tail falloffgtr_gamma(error)
Fresnel reflectionsfresnel(error)
Fresnel IORfresnel_ior(tick)
Lock fresnel IORfresnel_ior_lock(tick)
Metalnessmetalness(error)
Reflection Subdivsreflect_subdivs(error)
Trace reflectionsreflect_trace(error)
Exit colorrefract_exit_color
Softenhilight_soften
Enable dim distancereflect_dim_distance(error)
Affect Channelsreflect_affect_alpha(error)
Anisotropyanisotropy(error)
Anisotropy rotationanisotropy_rotation(error)
UV Vectors Derivationanisotropy_derivation
Anistotropy Axisanisotropy_axis
Refraction colorrefract(tick)
Refraction IORrefract_ior(tick)
Refraction glossinessrefract_glossiness(error)
Refraction Subdivsrefract_subdivs(error)
Trace refractionsrefract_trace(error)
Use exit colorreflect_exit_color
Affect alpharefract_affect_alpha(error)
Affect shadowsrefract_affect_shadows(tick)
Enable dispersiondispersion(error)
Abberationdispersion(error)
Fog colorfog_color(error)
Absorption distance
Fog multiplierfog_mult(error)
Fog biasfog_bias(error)
Fog multiplier in centimeters^-1fog_unit_scale_on(error)
Translucency typetranslucency(error)
Translucency colortranslucency_color(error)
Light multipliertranslucency_light_mult(error)
Scatter directiontranslucency_scatter_dir(error)
Scatter coefftranslucency_scatter_coeff(error)
Maximum thicknesstranslucency_thickness(error)
Double-sidedoption_double_sided(error)
Reflect on back sideoption_reflect_on_back(error)
Glossy rays as GIoption_glossy_rays_as_gi
Cutoffoption_cutoff(error)
Use irradiance mapoption_use_irradiance_map(error)
Energy preservationoption_energy_mode(error)
Fix dark edgesoption_fix_dark_edges
Glossy fresneloption_glossy_fresnel(error)
Use Environment Override use_environment_override
Environment OverrideBRDFVRayMtl / environment_override(error)
Environment Priorityenvironment_priority(error)
