This page provides some details on how to get V-Ray up and running.
Section | |||||||||||||||||
Installing V-Ray via Installer
The V-Ray installer automatically removes any previous installations. This allows you to seamlessly upgrade from previous versions. If you experience problems you can manually uninstall the previous versions to perform a clean install.
Tabs Container | |||||||||||||||
Installing V-Ray from Zip
V-Ray for Houdini can be downloaded from the V-Ray | Downloads section of the Chaos Group website (please make sure you use your login credentials to ensure access to the download links). It's recommended that you make sure your computer meets the System Requirements for running Houdini with V-Ray before installing V-Ray.
UI Text Box | ||
Please note that V-Ray is only supported on Qt 5 versions of Houdini. If you run into trouble starting up V-Ray for Houdini, please make sure you operate a Qt 5 version of Houdini before contacting us. |
Licensing V-Ray
Once V-Ray is installed you will want to make sure that your V-Ray license is properly configured. The Set Up Your V-Ray License page includes everything you need to get V-Ray licensed and running properly. You can download the License server installation pack from Chaos Group's website > Downloads.
When starting V-Ray for Houdini for the first time, you will need to manually load the V-Ray shelf. From the Houdini shelf, click the plus + icon, navigate to Shelves, and select V-Ray from the list.
Anchor | ||||
To render with V-Ray, simply press the Render button from the V-Ray Shelf. This will automatically create a vray_renderer node in the Network Editor (if one is not already present) and launch the V-Ray Frame Buffer.
