UI Text Box
typenote
Starting with V-Ray 5.0, when user attributes are used in the beginning of a file path, V-Ray will treat treats the path as absolute. For example, if a file node loads a texture from <userAttribute>/texture.png, the path will be is treated as absolute.
UI Path
