LoadLibrary – Loads a material library file that was previously exported from 3ds Max.
Use current LIB – Uses the current material library from the scene.
Covert LIB to .vrmat – Converts each material in the library to a separate .vrmat file.
Convert LIB in one .vrmat – Converts all materials in the library to a single .vrmat file.
Pick Convert Material – Selects a single material to be converted to a .vrmat file.
Convert Scene Materials to .vrmat – Converts all materials in the scene to separate .vrmat files.
width
5%
width
35%
Image Modified
Anchor
notes
notes
Fancy Bullets
type
circle
In order to see the V-Ray vrmat converter option on the Tools menu, V-Ray needs to register menus inside of 3ds Max. Normally, this is done by the V-Ray installation automatically, but in case the menu option is missing, it can be registered manually by entering the registerVRayMenus() command in the MaxScript listener.
