||obj Network|| > Digital Assets > V-Ray ShaderBall
Node
width50%
The VRay ShaderBall node provides inputs for controlling the shaderball.
width5%
width45%
Image Modified
Render Settings
width
50%
Mode
 – Selects the preview object.
Geo –
The preview object is a geometry.
Hair –
The preview object is hair.
width5%
width45%
Image Added
ShaderBall Settings
width50%
Image Removed
UV scale – Controls the UV scale of the object.
ShaderBall Base – When enabled, removes the shaderball base from the preview.
ShaderBall Inner
 – When enabled, removes the shaderball inner part from the preview.
Solid ShaderBall
 – When enabled, the shaderball uses one material. When disabled, different materials can be assigned to the separate parts of the shaderball.
ShaderBall Top – When enabled, removes the shaderball top.
ShaderBall Bottom – When enabled, removes the shaderball bottom.
ShaderBall Stand – When enabled, removes the shaderball stand.
width5%
width45%
Image Added
Light Settings
width
50%
Env Light – Controls the environment light.
Front Light – Controls the front light.
Back Center – Controls the back center light.
Back Left
 – Controls the back left light.
Back Right
 – Controls the back right light.
width5%
width45%
Image Added
Reset Material
Image Removed
width50%
Reset Materials – Resets the materials in the preview.
width5%
width45%
Image Added
