Section | |||||||||||||||
UI Path
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > Color Channel > Type > Caustics
Attributes
Section | |||||
Common Uses
The Caustics Render Element is useful for changing the appearance of rendered caustic effects with a compositing or image editing application. Below is an example of its use.
Compositing Formula
Caustics + Beauty = Final Image
Fancy Bullets | ||
