The Velocity Render Channel is a color or grayscale image that stores velocity information about objects that have moved between the current frame and the next frame.
The Velocity Render Channel stores surface velocity for moving objects in the scene with different colors representing different velocities. Each moving object is rendered with a flat color or gradient. It is commonly used to create mattes for adding motion blur in a composite.
Note: Specific objects can be excluded from this Render Element by disabling the Generate Render Elements option in the VRayObjectProperties node for the selected object(s).
UI Path
width5%
width45%
||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > Velocity
width45%
||mat Network|| > V-Ray > Render Channel > Velocity
width5%
width50%
The parameters for this render channel appear in the Parameters tab under the out Network and within the render channels node.
Image Removed
Name – The text added to the end of the rendered file, when saved as a separate file (e.g. myrender.Velocity.vrimg).
Clamp Velocity – When enabled, sets the limit for the Max Velocity value to 1 for floating print images, 255 for 8-bit images, or 65535 for 16-bit images. This option is useful only when writing to an 8-bit or 16-bit file format.
Max Velocity – Used to scale the velocity values written to the render element so that they fit within the range specifies by
the Clamp Velocity
 parameter. This is only useful if writing to an 8-bit or 16-bit file format.
Ignore Z – Disregards motion along the Z axis.
Filtering
 – Applies the image filter to this channel. Image filter settings are in
the AA sub-tab
 of the Sampler tab
 of the  V-Ray
 Renderer node.
Deep Output – Enables deep output.
width5%
width45%
Image Added
Fancy Bullets
typecircle
  • It is recommended to disable this render channel when rendering with Motion Blur. This channel is generated when 3D motion blur is enabled in V-Ray. However, the pass will also be motion blurred along with the rest of the image. This will make the element not usable in compositing.
