width33%
||mat Network|| > V-Ray> Texture: ProceduralTexture > V-Ray Fresnel
width33%
||out Network|| > V-Ray Render Elements node > V-Ray > Texture: ProceduralTexture > V-Ray Fresnel
width33%
Node
width50%
The TexFresnel node provides inputs for controlling various texture properties. They correspond to parameters in the section below.
width5%
width45%
Image Modified
width50%
Front Color – The color for the texture when viewed frontally (refraction color).
Side Color – The color for the texture when viewed at a grazing angle (reflection color).
Fresnel IOR – Index of refraction to use when calculating the Fresnel term.
Refract IOR
 – Specifies the refraction index of refraction for the underlying surface. This is ignored if the surface has a volume shader (the volume IOR is used instead).
Contribute to Fresnel IOR Render
Element – When enabled, the V-Ray Fresnel Texture contributes to the Fresne IOR Render Element.
width5%
width45%
Image Added
